Small issues/quirks
Yes, the exact same issue occurred with my Kona EV. I was at the grocery store on a hot summer day and I loaded my trunk with groceries. When I went into the cabin to drive, I received a warning light that the trunk was still ajar. I went out and closed it harder...went back inside...same message. Hmm...I drove off thinking it was a sensor issue and my instrument cluster was blank...completely blank... Like yourself, I used the heads-up display to see what my driving speed was. I went home, turned off my car, unloaded the groceries, and when I went back to my car and turned it on, everything was fine! I went to my local Hyundai dealer yesterday to report the issue. They suggested I keep track of it and to let them know if it should happen again. I'm glad (sorta) that another Kona EV driver is reporting the same issue. I always think it's just me. :)
Another issue I've had is when plugging in my iPhone X using a cable and then placing it on the self-charging pad, the entire display (8") goes blank and my iPhone does as well. This has happened to me twice. I also notice that the phone tends to get very hot, causing the phone to have very odd behaviors until it cools down. Hmm...
Item (1) Its either software crash or low 12V battery see this thread:
https://insideevsforum.com/community/index.php?threads/instrument-cluster-lcd-screen-frozen.6097/
Have not had it happen since topping off the 12V battery.
Not sure about item (2) but may be related , check the no load (minimal load) voltage is 12.6V or higher
I haven’t had any of these issues. And I have an iPhone X too
Somebody may already have posted this, but I'm not going to search through 14 pages to find it.
The cord that attaches the cargo cover to the rear door is very flimsy. I had a box in the cargo area that was just large enough so that the cover didn't lie flat, but I did not remove the cover. It didn't seem at the time that it would cause a problem, however when I went to open the rear door the cover apparently caught on something and ripped the cord right out of its end piece. I didn't force the door at all but just pulled it hard enough to get it moving. Had to remove the cord on the other side as well because if I leave it connected the cargo cover comes right off its hinges.
Hopefully the dealer will take care of this for me.
Those things are always cheap garbage. My last three cars the first thing I did was pull those out and chuck them in the basement. I still have them, pristine, even though the cars were traded in years ago! Security be damned. They are a nuisance and, as you pointed out, a cheap one.
The cargo cover seems very cheap, but it comes in handy to keep things like produce out of the sun. Maybe I'll stick mine in the garage as well and just get it out for my Saturday morning trips to the farmers market.
Well, my Kona has the low-end head unit and speaker system, no name branding or sub, and it does sound good with the .flac that I tested v.s. the same track saved as an MP3.
Doesn't the quality depend on the Bitrate for the mp3? I have all mp3s on my phone and they sound great. They are all high quality encoded. I also have the infinity sound system.
That is correct of course, but the flac does not use lossy compression like the mp3 so it's one less thing to question. The feature to read the flacs is just a good thing to have if you happen to have such files.
The past few days I've used the remote app to turn on the AC to cool the car before entry. It appears that the car draws on the internal battery for this (as the GOM drops upon activation). It was my understanding that the car was supposed to be smart enough to precondition the car using plug power when it's plugged in. Is there a setting to make sure this happens, because it's not.
