EV Range highs and lows
Is it a desktop version or apple app.
Both, I have an Android phone, but works on IOS as well. Did your dealer not explain all that to you when you bought the car? It allows you to remotely view and manage some of your car features, eg climate control, door locks, charging, etc. Very useful tool.
I've been trying to relate weight to range. I knew how much a gallon of gas weighed, does anyone know how much 64kwh of electrons weigh?;)
I've been getting around 450-475 km per charge lately. Drove a lot of highways lately.
Before charging to 70% today, I took the info from the dash as accumulated actual mileage of 196 km since last time I charged to 80%.
The actual percentage used for that mileage was from 80% to 42% = 38% of total pack capacity.
Doing the math 196/.38= 515.78 km
Of course one would not want to completely drain the battery, but even at 90% usage (464km) I am impressed. Right in line with your #s.
Pretty warm lately no rain or strong headwinds about 60/40 city/hwy (95km/hr).
We will see how that holds up when the inevitable monsoons return.
Nothing; the mass is the sum of the protons and neutrons
https://www.thoughtco.com/how-to-calculate-atomic-mass-603823
I'm not going to get into elements and periodic table stuff but according to this:
https://electricrevs.com/2018/12/20...e3ketRthNhzyyt5PmCCgw0Mq0iCaKqh2W_agNBtpcG0sA
each of the 294 cells weigh about 1.8 pounds = 529 pounds total (not including bus bars, bolts, wiring, bms and cooling system)
So I don't need to drive around with less than half a 'tank'.
That's good, it's a good thing it's not protons!!!!
Been driving about a month, using regen and ECO mode with little/no heater or AC -- getting regularly over 300 miles on 100% charge. Peak has been 322. You can see it nose-dive when you turn on the heater or AC :) I usually charge once a week (I'm retired, 0 commuting) but the mileage seems to match pretty well. As the weather warms and we need AC I'm sure it will drop off, but still way better than I expected.
A lot of people have been discussing EV Range, I was thinking it might be nice to see what others get for estimates when fully charged. My goal is 300 miles / 482 km, and driving pretty conservatively, I've managed to get to 297 miles on a full charge.
My current driving score is 98% economical and 2% normal. I live in a fairly hilly area, and the temps have been very moderate, between 40-70. I think the hills hurt a bit, obviously you can regen coming down the other side but I think it uses more power to get up the hill than you ever get back, so generally flat driving would likely be better, but I'm just guessing.
Here's my screen grab...
View media item 286
I have gone from around 297 to 337 miles on one charge. Looks like I will be pushing 350-360 on my next charge.
