What is the body plug fix? And what is an A01 service?
There were supposed to be 4 oblong oval rubber plugs installed at the Pre Delivery Inspection. About half the dealer’s don’t do this. The PDI says they are an important part for noise reduction but most of us don’t hear a dramatic difference.
The plugs and several other important aspects of the PDI are discussed in this thread:
https://www.insideevsforum.com/comm...spection-doc-esp-on-battery-replacement.2742/
The PDI doc below shows where you can look to see if the plugs were installed. It also tells you what else should have been done like battery testing and deflating the tire pressure from 50 psi as shipped to 36 psi.
Here are the Maintenance Codes from p 477 of the manual. A is oil change, 0 is just inspection, and 1 is tire rotation. The Maintenance Minder may move up certian items to make for fewer visits.
CODE. Maintenance Main Items
A
●Replace engine oil*1 and oil filter
●Inspect front and rear brakes
●Check expiration date for Temporary Tire Repair Kit
●Inspect these items:
•Tie rod ends, steering gearbox, and boots
•Suspension components
•Driveshaft boots
•Brake hoses and lines (including ABS/VSA)
•All fluid levels and condition of fluids
•Exhaust system#
•Fuel lines and connections#
•Stay RR, RR Subframe
•Under body battery cover
1●Rotate tires
2●Replace dust and pollen filter*2
3●Replace transmission fluid*3
4●Replace spark plugs●Inspect valve clearance
5●Replace engine coolant
7●Replace brake fluid*4
8●Replace air cleaner element*5
(There is no •6 because that is for a rear differential that we don’t have)
*1:If a Maintenance Minder message does not appear more than 12 months after the display is reset, change the engine oil every year.
#:See information on maintenance and emissions warranty.
*2:If you drive primarily in urban areas that have high concentrations of soot in the air from industry and from diesel-powered vehicles, replace the dust and pollen filter every 15,000 miles (24,000 km).
*3: Driving in mountainous areas at very low vehicle speeds results in higher transmission temperatures. This requires transmission fluid changes more frequently than recommended by the Maintenance Minder. If you regularly drive your vehicle under these conditions, have the transmission fluid changed every 47,500 miles (75,000 km) or 3 years.
*4:If a Maintenance Minder message does not appear more than 36 months after the display for item 7 is reset, change the brake fluid every 3 years.
*5:If you drive in dusty conditions, replace the air cleaner element every 15,000 miles (24,000 km).
(There is also an Emissions sticker under the hood noting to change coolant in 10 years and then every 5 yrs if MM does not indicate before then.)
