fishbert
... the existing SE is about 430 lbs heavier than the gas-powered version.
Is it really that much? Wow.
MINI USA lists the curb weight of the Cooper S as 2813 lbs (manual) / 2841 lbs (automatic).I've seen quotes all over the map, from 2870 lbs in the UK up to our 3140 (or so). The ICE S curb weight is listed at 2948 lbs.
MINI USA lists the curb weight of the existing Cooper SE as 3143 lbs.
I don't remember what weight numbers Google fed me earlier when I wrote that 430 lbs comment, but I probably just did bad math in the moment, since I was off by a round number (330 lbs more than the manual S).
And I was basing the next-gen Cooper SE weight off one of the video reviewers saying it was about 1600 kg (3527 lbs)... which does still check out at ~380 lbs more than the existing Cooper SE.
