Have you looked at
EV-A and decided it won't save you money?
You look like you're probably on E-1 (non-time-of-use tiered) or similar, which generally speaking is a
really bad deal with an EV unless you use very little power ordinarily, you also don't drive much, and for whatever reason you tend to use most of your electricity between about 1pm and 9pm. Once you get past even a modest amount of driving, you're in Tier 2, which costs a fortune--similar to peak rates on other plans, but all day.
If you drive a moderate amount to a lot, and either don't use that much electricity otherwise or can avoid the heaviest use during peak period (afternoon/early evening), EV-A will definitely be your best bet--just make sure your car (or charger) is programmed to start charging at 11pm. Then you're only paying 10 or 11 cents per kWh to fill up the car, and while peak power will be really expensive it's still only about what you're paying for Tier 2, and there are no caps. Non-EV time of use is also probably better, but unlike EV-A it still tiered, so is only likely to be worthwhile if you don't drive much and don't use much home power, either.
Incidentally, math-wise, the Clarity is rated at about 3.2 miles/kWh and 42 miles/gallon, which is to say that at Alameda-lowest price of $3.35/gallon using the ICE is the equivalent of about 25 cent/kWh energy (actually probably 22 cent due to charging inefficiencies). EV-A is about half that if you only charge at night (and you might also save money on your household bills if you usually ended up in Tier 2 anyway or can shift use outside peak period).
