Tyre pressure monitor Kona Electric Premium SE
Discussion in 'Hyundai Kona Electric' started by Colin Munro, Feb 19, 2020.
  1. Colin Munro
    Colin Munro New Member
    Has the Kona Electric got tyre pressure monitoring? If so how do I access it.
    Thanks
  3. Ricardowelch
    Ricardowelch New Member
  4. ericy
    ericy Well-Known Member
    They don't make it easy to find, that's for sure. If you look at the steering wheel on the right hand side, there is a button that looks like multiple pages. You can press that to cycle through several sets of pages on the right hand side on the instrument cluster, but that by itself isn't everything. On each page, you can toggle through numerous subpages with the up/down button that is just beneath that button. Eventually you will land on one that has a sort of diagram of the car, and it will show the tire pressure for each tire.
  5. Colin Munro
    Thanks I’ll go give it a try, although I did look through those pages an couldn’t find it the other day, I’ll try again. Colin.
  6. Colin Munro
    Found it, as you say not easy to find and the car has to be on the move for it to start registering, I suppose that’s to wake up the batteries in the various sensors. Thanks Colin.
