Torque Pro on the Kona - overview and setup for interested owners
Discussion in 'Hyundai Kona Electric' started by KiwiME, Sep 26, 2019.
  1. SkookumPete
    SkookumPete Well-Known Member
    That's not going to work. You have to open the .csv files as "raw", then copy and paste into your own .csv which is then loaded onto Torque. If the info in this thread is not enough, see the following:
  3. hobbit
    hobbit Well-Known Member
    Since I'm not actually using TP at the moment, I don't feel sure about
    trying to generate data in the exact form it wants. Every different system
    is going to have minor differences -- the order of items, extra fields,
    whether the bytes and math/equation is case-sensitive or not ... it's clear
    that the OBDlink / scantool.net people have leeched a lot of ideas from
    Torque and other interested communities, but they put their own twist on it.
    They can read .csv files, for example, but not save them out ... they're
    in a different order than Torque csvs. Parsing fields in the multi-packet
    answers is similar; it feels like that's a de facto "industry standard"
    since the early ELM327 days.
    I'd be happier talking about parameters in generic terms, i.e. which ID
    you send with, the mode and PID [whose total length varies], and where
    in the answer the bytes of interest are. I've had to adapt all of tne Jeju
    stuff from Torque format to the other format ... not hard if you understand
    what the fields are. And NONE of this gets anywhere close to the passive
    listening on an active bus that my old Scangauge does in the Prius -- if
    we could do that, it would be *much* faster. But in the Kona we don't
    get a live bus to listen to anyway, so everything here has to be query-based.
    Smarter people than I have probably already tapped the power-control bus,
    where all the interesting stuff happens, and are likely reverse-engineering
    the crap out of what's flying by. Probably with an eye toward creatively
    modifying some of it. The real asskicker here is that Hyundai and the rest
    offer NO help in understanding it. Because "right to repair" hasn't grown
    big enough teeth yet.
    _H*
  4. Domenick has moved the 12V battery discussion to its own thread: Tracking the 12v Battery with OBD2.
  5. Here's a rundown on my take on CEC and CED. These are effectively odometers for energy going into and out of the traction battery as a whole, all 98 series packs of three cells in parallel. Passing current is measured precisely inside the battery using shunts. Current times the voltage, integrated over time, is energy and CEC and CED are incremented separately depending on the direction of the current. The usefulness of these numbers is first due to the fact that they are separately tabulated, second because they are cumulative over the life of the battery.
    Over time, the values graphed would look like two diverging lines starting at zero when the registers were initialized at the factory. The first graph below is a mockup with straight lines to help us understand the theory; the lines are actually going to be wiggly in detail. Also recognise that when these registers were zeroed the battery would have some initial non-zero charge, let's call it SoCo.
    The first outcome to note from this is that whenever the current SoC is the same as the initial SoCo, the battery's cumulative overall efficiency is simply the ratio of the current values of CED over CEC. (If the current SoC is not the same as the factory SoC, the CEC is higher or lower by that difference).
    The important takeaway at this stage is that we have four numbers on hand so far. CEC and CED, the initial SoCo, plus the average battery efficiency to-date calculated from those first three values.
    The actual logged values on the next graph below have been offset by a fixed number for each curve to allow a detailed view of the changes while alternately driving and charging over a period of about an hour. You can see that while driving there is more discharging going on to move the car than there is charging due to regen. When charging there is no movement of the CED value because the car is not moving. Note, while charging, power used to keep the systems running is drawn from the charger before it enters the battery. You can see clearly where the charge rate changes due to charging tiers, battery heater heater activity and/or other uses of incoming power while waiting.
    You'll note that over a trip, from the change in these values you could calculate how much regen energy is recovered v.s. how much energy is spent.
    Now onto the last item. The main purpose of these registers as best as I can determine is to calculate a stable current SoC, not affected by pack voltage that may vary under load. Apparently this technique is called "coulomb counting" and there are numerous studies on the subject if you care to google it.
    As I mentioned above, when the current SoC is the same as SoCo, the cumulative battery efficiency is just CED over CEC. But, since battery efficiency could be assumed stable over the few last charge cycles, you can assume an efficiency based on past data and work back to get the current SoC even if it's not the same as the starting SoCo. For that you also need to know the battery capacity because both SoC values are a percent of that, resulting in kWh. CEC and CED are also expressed in kWh.
    Battery losses occur for several reasons during charging and discharging. The SoC represents the stored energy in the middle of that process. If you add energy during charging you lose a tiny bit going in, the result increasing SoC representing slightly less than what you put in. However, you don't yet know what you lose discharging because you haven't done that yet and therefore the SoC cannot reflect that further loss.
    For simplicity I've assumed that those losses are equally spread between charging and discharging. On my Kona I've worked that out to be 96% total, where the charging and discharging efficiencies will be each the square root of that total value.
    The following formula and graph are a simplistic use of these numbers to determine current SoC. I say 'simplistic' because I'm sure the technology is much more complicated mathematically, but this gets close. So, CEC and CED are each modified by the square root of the total efficiency and the resulting difference is offset by the factory SoCo to get the current SoC. The constants assumed are noted below, SoCo, total battery capacity and overall efficiency.
    Over the same driving/charging data as the graph above you can see that my estimated charge in green (SoC EST) emulates the displayed charge in red (SoC DIS) very well.
    Please ignore the blue SoC (BMS) on the graph, that's outside the scope of what I'm covering in this post.
    TheHellYouSay and milesian like this.
  6. FloridaSun
    FloridaSun Well-Known Member
    When I go to github, I can find the files but I can't find the download button?? How do I download from there?
  8. FloridaSun
    figured it out. Got all the displays now.. now I need to understand what the values mean, especially those battery related..
  9. FloridaSun
    All my cells except for #31 have 3.88 volt and 31 has 3.86 volt. Is that a problem?
  10. ericy
    ericy Well-Known Member
    I wouldn't think so.
  11. Give it a full charge, they should all equalize, plus it will give you an opportunity to look at your top end buffer size. BMS should report 95-96% when your display reports 100%.
  13. FloridaSun
    Thx.. will try that.
    I will charge to 100% on Thursday night as I'm leaving on a small road trip on Friday.. 210 miles to the closest level 3 charger at my destination. I could take a 15 mile longer route that has several Level 3 along the route, but I prefer the shortest route.
    Right now, SOC (display is 74.5 and SOC/BMS shows 72.5).
    Based on my calculation, the total buffer on the Kona should be 4.62% when new. So, 95.38% when the car is new..
    Battery size is 67.1 kwh, available to owner, 64kw..
  14. That's about right, I get 1.5% difference at similar SOC.
  15. Yeah , I have seen that 67.1 kwh gross battery capacity number thrown around a couple of web sites, not sure if its an official number. I just know when my battery was brand spanking new torque pro reported the BMS reading as 95% when the display indicated 100%. I believe Kiwime indicated his is 96%, so there is probably a little variation. I hope that helps.
  16. FloridaSun
    I wonder if the 000_Battery_power value is the charge the car is receiving?
    The display shows charging at 7.4kwh and battery power shows about -6.9kw
    Would be a 7% loss. Not too much..
  17. Seems like a reasonable assumption.
  18. FloridaSun
    That would perfectly match the 67.1 kwh battery size, so those numbers seem to confirm that.
    Brand new should be 95.3%. I'm approaching 22k miles now, so I don't expect to still have that much buffer.
  19. 20 mv differential is not an issue,as a matter of fact that is pretty good; just keep your eye on it to ensure the equalization process is working as it should.
    I believe the Kona pack has 3 parallel cells per unit of measurement so a defect in one will be hard to recognize until it drags down the voltage of the other two.
    I wonder if the cells in question are in the "stacked" module below the rear seat where coolant circulation might be slightly less.
  20. I think you will likely have it all. I suspect you will have not much if any degradation at 22,000 miles. The Bolt has very similar LG packs to ours. This Bolt owner calculates a 5-8% degradation over 105,000 miles. https://www.torquenews.com/8861/chevy-bolt-ev-battery-health-after-100000-miles
    FloridaSun likes this.
  21. FloridaSun
    Last night, I charged to 80% and all cells ended up with 3.92 Volt, so the discrepancy on #31 was gone.
    electriceddy and Esprit1st like this.
  22. FloridaSun
    Mine showed 95.5% BMS at 100% on the Display..
  23. It seems your top end buffer is intact, and it will be a good baseline reading to compare to as your battery ages.
