Repair issues and fixes
Discussion in 'Hyundai Kona Electric' started by Francois, Oct 7, 2019.
  1. Hopefully the creator of the post I referred to chimes in with an update :
    this one from 2 weeks later
    https://insideevsforum.com/community/index.php?threads/transmission-replacement-at-9000mi.7386/page-3#post-87867
    robxb likes this.
  3. Category: Drivetrain
    Issue : Clicking Sound at low speed acceleration / higher-pitched rumbling at higher speed acceleration
    Possible Fixes:
    (1) Rotate Drive Shaft 180 degrees
    (2) Replace Reduction Gearbox
    (3) Replace E700 motor with E701 motor (installed with larger (4) x "11404 12756p : BOLT-FLANGE")
  4. robxb
    robxb Active Member
    How is it now, 6 months later? Still no sound, or has it returned? How far have you driven since it was replaced?
  5. ehatch
    ehatch Active Member
    All's good,there's a slight "noise"while coasting,or parking lot low speed acceleration. Nothing like before where I sounded like I needed a brake job.Or in the video I posted driving in circles in a parking garageo_O
  6. ehatch
    For me,with COVID19 situation,I have probably done about 10000km/6213miles. The squeal,break noise hasn't returned.
  8. ehatch
    It's still a fairness issue compared with gas.To see a poor late model leaf only pull about 20kW compared with my 40kW on a 50kW is wrong when it's time based fee versus kWh.
  9. cmwade77
    cmwade77 Active Member
    All charging should be based on kWH, it is a simple matter of fairness.
    syntaxfx and navguy12 like this.
  10. Well, there should be an incentive to not charge to 100% on a fast charger. So a time and kWh based price might be a good solution in the end.
    However, fairly priced it needs to be.
  11. cmwade77
    Perhaps making it prices per kWH only up to 80% and then by time makes sense?
    But I also disagree to a point, the Kona charges at 50kw until around 92% on a 50kw charger.
  13. I charged the other day at a 50kw (BC Hydro) charger, and it showed only 24k at 80%. Another person with an i3 showed up so I let him take it then. I know they have a smaller battery, and I had more than enough to get home.
    Kirk, David Thornton and Esprit1st like this.
  14. cmwade77
    As I would have done as well, where I charge there are two stations and my Kona keeps going to a little over 90% at 50kw, perhaps it is because of reasonable temps being I am on Long Beach, CA?
  15. When I got home, I checked plugshare to see the kw of that charger, as I know some are only 25kw max, but it said 50. Temps were not that cool, 28C, and I was driving just before, so I think my battery should have been warm. I know in the past on other chargers I have seen near 50 and more (if it was a higher power charger), when the SOC was much lower.
  16. cmwade77
    In general, it is about 70F (21C) when I charge, maybe that's the difference? Or is it because the charger I wason stopped at 80% or so and I restarted it since no one was waiting?
  17. A good solution is to put an L2 AC charge outlet accompanying the DC charger so one can continue at a slower rate if required while freeing up the faster DC charger for others.
    Kirk and R P like this.
  18. Yes, some of the newer BC Hydro stations here have that.
  19. Why would anyone place an electric charge port on the nose of the car? Hyundai is not alone in this. It will be covered, even filled, with mud and frozen with salty wet road dirt in the winter. What was wrong with the front fenders??
  20. ericy
    ericy Well-Known Member
    Front fender would also work. Any car with a charge port in the rear fender has trouble getting charging cables to reach however.
  21. cmwade77
    Umm, this is exactly where I want the charge port to be, anywhere else and you have to deal with backing into spaces to charge and really how would you be getting that much mud? Do you guys go off roading with this?
    Kirk likes this.
  22. You don't need to go off roading. Watch the Kona winter test video by Bjorn. The radar sensor on my Prius got covered in the winter regularly which and makes the unit fail. We just sold our 2012 Mitsubishi iMiEV, which had the charge port on right rear. My Clipper Creek charger with 25ft long charger cable solved the problem. Backing up with rear view camera is still a challenge? I hope you are kidding.
  23. cmwade77
    No, I am not kidding, especially in the MANY areas in California where backing into parking spaces is illegal and carries fines of up to $1,200 for doing so, no backup camera overcomes that. And I have a 25 ft charger, but that won't help me when out an about.
    Kirk likes this.
