Hondalink app errors on android
Discussion in 'Clarity' started by ozy, Jan 29, 2019.
  1. ozy
    ozy Active Member
    Not sure if it's my phone or something else, but I'm finding Hondalink on android to be a bit buggy. I often get error messages relating to "network error...retry" even though I have full cell reception. Also, when I open the app it gives me my HV mileage but not the EV . Hitting refresh doesn't seem to help. There's also a lag ie: when it's on a public charger it doesn't really indicate for me the current level of charge as it's charging. For example, it reads at 10% for one hour but when I return to the car I realize it's at 50%. I tried to call tech support there a few times but gave up after a long hold. Is it just me?
  3. David in TN
    David in TN Well-Known Member
    I have a Samsung Note 9. No connectivity issues. I'm on , Verizon.
    The HondaLink app updates periodically. A way to force an update is to go to Vehicle, then choose Find My Car. Select Locate Vehicle. Wait a minute for it to update. Then return to dashboard and refresh.
  4. ClarityDoc
    ClarityDoc Active Member
    I have a Google Pixel with Android 9 (Pie) with none of those symptoms (since starting to use it with my Clarity in May). Sounds like a job for the dealer, or removing/reinstalling HondaLink app plus perhaps rebooting the display unit in the Clarity (long press on the power button).
  5. MPower
    MPower Well-Known Member
    Samsung Galaxy S7 Edge, android 8 Oreo - no problems so far.
  6. Olimpia
    Olimpia Member
    Google Pixel XL on Verizon here. The app seems to work fine 90% of the time for me.
  8. Daniel M W
    Daniel M W Member
    Samsung galaxy S9 and I have exactly the same behavior. Laggy at public chargers, shows network issues, wrong info about battery charging percentage. I've never call to Honda service, but maybe I will give it a try so they can check and see if find something
  9. ozy
    ozy Active Member
    I called Hondalink and they were not helpful. Suggested that I should reinstall the app, uninstall and reinstall bluetooth, do a factory reset on the car etc. I tried David in TN's suggestion and it seems to work. I think that's the easiest route for now.
