Charging to 80% ? 100% from ?
Discussion in 'Hyundai Kona Electric' started by Tim94549, Dec 22, 2019.
  1. Tim94549
    Tim94549 Active Member
    Last night I had this discussion with a TESLA owner. He says that he charges his TESLA every night to 80%, regardless of how low the batteries are. When we took possessions of our KONA EV, we were told to allow the batteries to go down to like 10-20% to plug in and charge to 100%.
    Anyone know the real technical details on this issue? Or able to point me to a specific recommendation? We really don't use the vehicle that often, so I've been reluctant to just leave it plugged in every night and rather allow the batteries to drain over a week or so. What do YOU all do for charging?
    Thanks in advance.
  3. SkookumPete
    SkookumPete Well-Known Member
    BC-Doc likes this.
  4. Tim94549
    Thanks !!!
  5. Murry
    Murry Member
    Whoever told you the 10-20 to 100 advice shouldn’t be selling EVs.
    Ev050 and KiwiME like this.
  6. I set the charge limit to either 60 or 70% and plug in (using the 230V 8A trickle charger) at night gaining 2% per hour. The most I use in a normal day is about 10%.
    If I need 100% for a trip I can either charge at home for a full 24 hours or visit a nearby public DC charger to fill in the gap.
    That saves me about $3,000 for a 16 or 32A outdoor EVSE install.
    David Thornton and Tim94549 like this.
  8. I follow SkookumPete referenced takeaways. I generally anticipate driving 50-100 km day so I keep my max SOC 70% and charge every evening, with a charge range typically between 50-70%. Ultimately charge to what your needs are. If you really need a 100% of the battery its less than ideal on a continued basis but the battery has safeguard buffers in place to protect itself so don't stress over it too much.
    https://batteryuniversity.com/learn/article/bu_1003a_battery_aging_in_an_electric_vehicle_ev
    Simple Guidelines to prolonging the EV battery
    • Limit ultra-fast charging, especially when the battery is cold. Use Level 2 when possible.
    • Only charge the battery to the level needed for the daily routine. Full charge hastens capacity fade.
    • Do not discharge the battery too low as this increases the internal resistance. Charge more often.
    • Charge and use the battery at room temperature. Operating when cold reduces capacity.
    • Store the battery in a cool place at partial charge. Usage and storage have different requirements.
    • Moderate the battery to room temperature in winter before charging and driving. The BMS may do this automatically.
    • Charge the EV after a sabbatical. Resting at low charge reverses capacity fade.
    • It is best to let the battery rest at low SoC and only charge before use. Dwelling at low charge reduces calendar aging and may also reverse capacity fade.
    Lab Observations
    • At 40°C (104°F), battery efficiency is above 95%, but stress levels are high. At 25°C (77°F), the efficiency is between 93–95%, and at 10°C (50°F), the efficiency is only 89–92%.
    • SoC above 80% hastens cathode degradation, discharging below 20% increases internal resistance.
    • Capacity recovery is only possible at a SoC at 50% and lower over time.
    • The EV fuel gauge is not absolute. The accuracy can be improved by an occasional full charge and deep discharge toe reset the flags. This exercise is similar to calibrating a smart battery. (See BU-603: How to Calibrate a “Smart” Battery.)
  9. FloridaSun
    FloridaSun Well-Known Member
    On Lithium Ion batteries, you will get better life if you charge to 80% and to 100% only when you need the range. It's best to charge every day and don't let the SoC drop too low except when you have no choice on road trips. I usually use 20 to 30% of charge each day, so I charge every night from somewhere between 50 to 60% back to 80%. Whenever I go on a road trip or expect over 150 mile of driving in one day, I charge to 100%.
    Ev050 likes this.
  10. mikeselectricstuff
    You should periodically charge to 100% so the BMS can balance the cells
    SergioGomes24 likes this.
  11. Tim94549
    Thanks everyone for your words of wisdom. Very good information here for a newbie. We installed a LEVEL 2 charge a week ago.
    Kathryne likes this.
  13. Thanks for this thread! I’ve learned a lot. So now I have set up my Kona for 80% charge in both AC and DC, set a charge schedule so the battery has time to rest between use and charge in time to leave in the morning, and will once a week not charge and bring the charge level down an extra 20-25% between charges (I commute 100k per day)
    Does that sound about right?
  14. That sounds perfect
  15. So I set a schedule to prioritize charging between 8pm and 8 am with a departure time of 7 am. My battery charge pattern is significantly different than when I just plug in without schedule. See below graphs for the last 3 days.
    I don’t understand why it’s not charging based on departure time. Instead it gradually ramps and at 8pm starts pulling full charge rate.
  16. hobbit
    hobbit Well-Known Member
    Y'know... this makes me think that if *phones* had the ability to set
    maximum charge limits instead of going to 100% all the time without
    intervention, that people wouldn't complain so often about having
    to get a new phone because the old one would no longer get them
    through a day. For "devices" I've gotten more into the habit of
    keeping an eye on the SOC and pulling the plug around 90% ...
    I don't always catch it right, but it probably helps.
    _H*
  17. FloridaSun
    when it comes to phones, technology is moving very fast.. Most phones are outdated after 2 years, so most people don't even keep them long enough to have significant loss of battery capacity.. I usually change phones every 2 years which gets kind of expensive as prices have come up.. You can barely get a good phone for under US$ 1000...
  18. ericy
    ericy Well-Known Member
    Well you *used* to be able to easily replace the battery in a phone, and it was a lot cheaper than buying a new one. But in the mindless search for thinner phones, all that went away, and now you need to take it in and have someone do it for you.
  19. I suspect this may become an issue for EVs. Lets say we keep our EVs for 10 years will the current battery tech even exist to be supported if a replacement is required? I suspect we are starting to see cars following the disposable technology obsolescence trend that now exist in phones.
  20. ericy
    The difference is that replacing an EV's batteries is going to be hugely expensive. Although as time goes on, those costs go down as batteries get cheaper. But once the car gets to be a certain age, you have to decide whether to replace the battery or get a new car. No different from an ICE car when the engine blows up.
    I gather that there are people scarfing up used EV batteries for other purposes (battery backup for solar, and other such things).
  21. FloridaSun
    I was a big fan of removable batteries.. Until the Note 4, Samsung batteries could be replaced easily in a few seconds.. I actually always got the aftermarket extended size battery which would last 3 x as long as the original battery.. Sad that they stopped offering that feature.
  22. FloridaSun
    Luckily, not something that US buyers of 2019 Konas have to worry about :-D
  23. davidtm
    davidtm Active Member
    Check out the app AccuBattery. It can't stop the charging, but it does have an alarm to alert of the charge level you select, health stats, etc.
    Sent from my P027 using Tapatalk
